Marcos 8042 Build (currently 9,221 views) |
Mike_Smith |
Fabricated a simple hold-down for the spare tire. |
Mike in Victoria BC - building 8042 |
Reply: 75 - 89 |
Mike_Smith |
A wheel nut keeps everything in place now. |
Reply: 76 - 89 |
Mike_Smith |
Front carpet and seats now installed for the last time! |
Reply: 77 - 89 |
Mike_Smith |
Rear carpet sections laid in place. Looks more like a finished car now! |
Reply: 78 - 89 |
Mike_Smith |
Hood latches fitted and adjusted to hold hood from vibrating. |
Reply: 79 - 89 |
Mike_Smith |
Side mirrors mounted on the doors. also window lit handle..small bocks of plexiglass bonded to top of window. |
 | Last modified August 23rd, 2022, 16:06:16 by Mike_Smith |
Reply: 80 - 89 |
Mike_Smith |
Door panels installed. |
Reply: 81 - 89 |
Mike_Smith |
a much more inviting interior now that its all together |
Reply: 82 - 89 |
Mike_Smith |
The car has been started and run up the street. There was a bit of lag with the Weber, so a local carb tu9ng guy has dropped by to sort out some fine tuning on the car. It runs much better now and pulls fairly well for an 1100. |
Reply: 83 - 89 |
Mike_Smith |
Posted on: August 23rd, 2022, 16:13:38 |
A few small details to sort out, but finally the car is running, driving and pretty much finished. I have mounted new tires and set up the alignment using the string method. I goes in for a professional alignment in the next few days. For now I am putting a few km on it each day breaking in the engine and looking for any other issues. So far it seems good and is fun to drive!
Is there a way to post a first drive video? |
Reply: 84 - 89 |
Mike_Smith |
Finished car |
Reply: 85 - 89 |
Posted on: August 23rd, 2022, 18:27:06 |
Fantastic job, looks really good and you've done a whole lot in not much time. Mike |
Reply: 86 - 89 |
Mike_Smith |
Quoted from mike brown, posted August 23rd, 2022, 18:27:06 at here |
Thanks for the kind words Mike. I did have the advantage of having the engine already rebuilt and ready to go. But as others may know, it's not a "quick and easy build" as was advertised in the brochures..
I appreciated the help I had getting questions answered on the forum.
This is how it all began! |
Reply: 87 - 89 |
Posted on: October 1st, 2022, 15:27:05 |
'Rear carpet sections laid in place. Looks more like a finished car now!'
Mike, the car looks great. A question - in the above photograph, how did you do the rear wheel arch covers. These look a damn sight neater than what I've achieved for my car! |
Last modified October 1st, 2022, 15:28:25 by Graham Bichard |
Reply: 88 - 89 |
Mike_Smith |
Posted on: October 1st, 2022, 23:58:49 |
Quoted from Graham Bichard, posted October 1st, 2022, 15:27:05 at here |
I used some automotive upholstery spray contact cement. I sprayed and stuck down the top of the wheel arches first fitting it as tight as possible. Then I did the lower part and sides. I sliced slits in the edges along the floor where it made sense to allow me to have a tight fit on the sides and wrap along on the floor. . I think it looks better in the pictures as it's by no means perfect. I also had to fit and tuck around the seat belt bar, which is why I did the top first. Hope this helps.
Reply: 89 - 89 |
