  Mini Marcos Forum  >  General Boards  >  Mini Marcos  >  Marcos 8042 Build
0 Members Browsing (6 Guests)
Pages: « 1, 2, 3, 4, 5, 6 » : All Reply Recommend Print
  Author    Marcos 8042 Build  (currently 4,708 views)
Mike_Smith
Posted on: June 15th, 2022, 02:29:59
Wiring harness wrapped and ready for final installation
Mike in Victoria BC - building 8042
Private Message Reply: 45 - 89
Mike_Smith
Posted on: June 15th, 2022, 02:33:30
Pretty much all the firewall holes have been drilled for wires, throttle, speedo, choke etc... with the fiberglass so much thicker than a typical steel mini firewall, I had to find grommets to accommodate the thickness. and in some cases grind carefully around the hole so the grommet would fit.
Private Message Reply: 46 - 89
Mike_Smith
Posted on: June 15th, 2022, 02:34:54
The fuse box and the turn signal/4 way flasher hides in the glovebox area.. to be covered up with a small glove box container.
Private Message Reply: 47 - 89
Mike_Smith
Posted on: June 15th, 2022, 02:35:29
The glovebox interior...
Private Message Reply: 48 - 89
Mike_Smith
Posted on: June 15th, 2022, 02:36:04
And the secret door to find the fuse box!
Private Message Reply: 49 - 89
Mike_Smith
Posted on: June 15th, 2022, 02:38:05
Wiring harness all fitted, hooked up and tested on the car. Ran into one strange issue as LH rear signal lamp would come on with the Park lights.. eventually found a short in the front LH turn signal lamp housing. All goo now.  Dash now fitted to the car as well as the top dash pad and rear view mirror.
Private Message Reply: 50 - 89
Mike_Smith
Posted on: June 15th, 2022, 02:40:29
The small front panel on the nose is not being installed on the car, so I am building a grill which covers the hole between the hood and the body of the car. It's made from some generic ABS grill panels material and will be removable with 2 small bolts.
Even the interior light works.. you can see the door switches in the picture. For now as the doors are off the battery will be disconnected.
Last modified June 15th, 2022, 02:41:38 by Mike_Smith
Private Message Reply: 51 - 89
Mike_Smith
Posted on: June 15th, 2022, 02:42:09
A close up of the grill in the opening..
Private Message Reply: 52 - 89
Mike_Smith
Posted on: June 15th, 2022, 02:42:35
And a shot from farther back..
Private Message Reply: 53 - 89
Mike_Smith
Posted on: June 15th, 2022, 02:43:39
Drive shafts rebuilt with new CVs, all new boots and greased up..
Private Message Reply: 54 - 89
Mike_Smith
Posted on: June 15th, 2022, 02:44:29
All cleaned up, painted and reassembled. Ready to install on the subframe and engine.
Private Message Reply: 55 - 89
Mike_Smith
Posted on: June 15th, 2022, 02:45:12
And installed....
Private Message Reply: 56 - 89
Mike_Smith
Posted on: June 15th, 2022, 02:45:56
Brake pads installed for the 7.5 inch disc brakes..
Private Message Reply: 57 - 89
Mike_Smith
Posted on: June 15th, 2022, 02:47:15
Heater connected for defrosters, and heater cable installed under the dash on a bracket, rather than on the wood dash..
Private Message Reply: 58 - 89
Mike_Smith
Posted on: June 15th, 2022, 02:50:08
I attempted to install the engine and sub frame so I could get everything else attached, but ran into difficulty  using the radiator I was supplied. It was an aftermarket aluminum one and was too thick to fit.  So off to the supplier to find a stock sized Mini one.. This picture shows how far over the rad would have to be to clear the side on the inner fender well.
Private Message Reply: 59 - 89
Powered by e-blah Platinum 7 Final © 2001-2004   -   October 6th, 2022, 06:42:54
Files opened: 58 | Files closed: 58
