Marcos 8042 Build (currently 9,222 views) |
Mike_Smith |
New radiator fitted and ready to drop the body over.. |
Mike in Victoria BC - building 8042 |
Reply: 60 - 89 |
Mike_Smith |
Down she goes.... |
Reply: 61 - 89 |
Mike_Smith |
And shes in.. now to finish up with the rest of the bolts, add the shifter rods, exhaust manifolds, carb distributor and hook up all the engine wiring.. custom gas tank out being Tig welded up so have to get that back before I can think about firing it up. |
Reply: 62 - 89 |
Posted on: June 17th, 2022, 17:32:40 |
Great progress. It's going to be a sweet car once done. Mike |
Reply: 63 - 89 |
Mike_Smith |
Posted on: June 26th, 2022, 02:39:06 |
Quoted from mike brown, posted June 17th, 2022, 17:32:40 at here |
Thanks for the kind comments!
Reply: 64 - 89 |
Mike_Smith |
Picked up the custom fuel tank I was having welded up today.. will allow a lot more distance between fill ups. Now to fit it to the car and align the filler tubes. |
Reply: 65 - 89 |
Mike_Smith |
With the engine and front sub frame in place I was also able to cut out the hole for the shift lever and the mounting bracket holes. Now installed on the car. |
Reply: 66 - 89 |
Mike_Smith |
Fuel tank mounted in the car.. |
Reply: 67 - 89 |
Mike_Smith |
Filler tube with gas rated hose and stainless T clamps |
Reply: 68 - 89 |
Mike_Smith |
Locking gas cap to finish it all up. |
Reply: 69 - 89 |
Mike_Smith |
Seat belts fitted to car.. will have to come out to fit the carpets.. but I now lknow they will work. |
Reply: 70 - 89 |
Mike_Smith |
Rear belt bar. |
Reply: 71 - 89 |
Mike_Smith |
Engine pretty much plumbed and cables sorted. Just needs heater hoses and the last bit of wiring for the starter solenoid and ignition system. |
Reply: 72 - 89 |
Mike_Smith |
Rubber seals mounted onto the rear hatch lip. Two sizes were used to make sure the rear hatch could close as the top fitting is very tight for room. |
Reply: 73 - 89 |
Mike_Smith |
Interior carpets being fitted. The shape and size of each wheel well is not the same, so difficult to get a good fir . but looks ok in the end. |
Reply: 74 - 89 |
