  Mini Marcos Forum  >  General Boards  >  Sport  >  harnesses
0 Members Browsing (6 Guests)
  Author    harnesses  (currently 1,009 views)
Grant Wilson
Posted on: August 7th, 2009, 22:47:13 Quote Report to Moderator
LeMans -- 2016
hi,
As I continue to try and finish my cay for the anniversary I again have a question for the forum.
I have harnesses and am unsure where to mount the rear straps. does the 'blue book' allow you to drill through the roll cage, wrap around the cage, or should I just bolt to the rear floor pan?
thanks as always
Grant
Tim Neal
Posted on: August 8th, 2009, 03:31:33 Quote Report to Moderator
If the rules are anything like our in NZ you can't drill the cage if its been certified/homolagted to the car.
My belts are wrapped around the rear roll cage lateral bar. Not a great angle to try and get a picture!
Private Message MSN Reply: 1 - 3
Allan Brown
Posted on: August 9th, 2009, 21:24:17 Quote Report to Moderator
Mine are wrapped around the roll cage as well.
Private Message Reply: 2 - 3
Guy Humphries
Posted on: August 11th, 2009, 10:51:42 Quote Report to Moderator
Mine too! Just remove the hook clip from the end of the rear straps & wrap round the cage cross bar.
Private Message Reply: 3 - 3
New Thread Mini Marcos Forum  >  Sport  [ previous | next ] Switch to:
Powered by e-blah Platinum 7 Final © 2001-2004   -   September 24th, 2021, 19:04:31
Files opened: 85 | Files closed: 85
