Heated Screen Current Draw (currently 339 views) |
Ron_Murrell |
Posted on: June 11th, 2023, 07:07:02 |
Does anybody know what current the heated screens draw? Do I need a relay? I intend to switch it with a standard Mini toggle switch (single pole/single throw). regards Ron |
Posted on: June 11th, 2023, 21:18:19 |
I don't know what they draw but it will definitely need a relay and I would recommend one that cuts out after 10mins or the voltage drops below about 12v. Otherwise you'll melt the switch or flatten the battery. Mike |
Reply: 1 - 3 |
Ron_Murrell |
Posted on: June 11th, 2023, 22:51:51 |
Thanks Mike that is a great point. That has got me thinking that I should also incorporate a warning light. The timer relays that I have found, so far, can only switch 10 amps so I really should find out the potential current draw also. regards Ron |
Reply: 2 - 3 |
Posted on: August 14th, 2024, 10:42:06 |
You can get one-shot timer modules on ebay, but I haven't found any data sheets for them. They have relays on the board so the contacts are voltage free. You don't need extra relays. |
Last modified August 14th, 2024, 10:44:49 by admin |
Reply: 3 - 3 |
