Pages: « 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12 » : All |
I have started to build the MK1 Jem (currently 7,845 views) |
Goff_Allen |
Posted on: January 28th, 2018, 16:31:10 Attachment: 116.jpg - 173.38 KB (1150 views) |
Engine |
Reply: 90 - 167 |
Goff_Allen |
Posted on: January 28th, 2018, 16:31:45 Attachment: 117.jpg - 189.87 KB (1144 views) |
Head |
Reply: 91 - 167 |
Goff_Allen |
Posted on: January 28th, 2018, 16:35:14 Attachment: 118.jpg - 144.56 KB (1146 views) |
Head , I had to fit the small bore push rods as they are shorter and head studs as they threaded longer , Also drilled and tapped the block for extra two studs. |
Reply: 92 - 167 |
Goff_Allen |
Posted on: January 28th, 2018, 16:44:24 Attachment: 121.jpg - 132.56 KB (1151 views) |
Nearly built up , Fitted later type out put shafts to the gearbox |
Reply: 93 - 167 |
Goff_Allen |
Posted on: January 28th, 2018, 16:45:25 Attachment: 122.jpg - 121.54 KB (1145 views) |
Lot of bits from other engines |
Reply: 94 - 167 |
Goff_Allen |
Posted on: January 28th, 2018, 16:50:07 Attachment: 110.jpg - 175.37 KB (1149 views) |
Engine Block |
Reply: 95 - 167 |
Posted on: January 28th, 2018, 17:20:39 |
You may need to change the rocker box my mk2 was tight with a standard tin one. Mike |
Reply: 96 - 167 |
Goff_Allen |
Posted on: January 29th, 2018, 19:30:24 |
Quoted from mike brown, posted January 28th, 2018, 17:20:39 at here |
Yes mike , it does look to big ,When the engine is fitted i will see how it goes ,not going to alter the bonnet ,Maybe cut it down and re-weld it is an option. |
Reply: 97 - 167 |
Goff_Allen |
Posted on: January 29th, 2018, 19:35:54 |
Quoted from Goff_Allen, posted January 28th, 2018, 16:14:09 at here |
Had a good week ,Been building the engine up , Its a bitsa engine & gearbox Rod change -1300 Pre + k from a scrap yard in Doncaster , The diff pin gear came loose and smashed the geabox casing + planet gears £120 , Block rebored +10 ,cam bearings fitted and decked about 6 mm , Crankshaft from South Africa £200 , regound 10 mains , 10 big ends , Its works out just under 1100 cc , Head from Manchester , 1300 GT off ebay for £40 ,listed as a bog standard 1300 though it needed a full recon including exhaust valves , Mini spares Evo 2 cam , Gearbox came from Nottingham for £50 ,standard from a Mini 1000 last of the remotes , Stripped down all new bearings , Syncros, second gear and a minispares cross pin diff Should make a nice fast road engine , Rest of the bits from a couple of engines.
Graham i am sure this shell has a had a repair done after it left the factory , I am going to remove the rear subframe and move it over , re-drill the holes. |
Reply: 98 - 167 |
Goff_Allen |
Posted on: February 3rd, 2018, 20:38:47 Attachment: 125.jpg - 188.81 KB (1147 views) |
Here is the back view of the engine showing pot drives i replaced the cross joints , Bought twin 11/4 SU from ebay £80 , came of a 998 cooper according to the number on the manifold ,good condition needing the rubber mounts between bowls and body , Spindles OK ,gave them a good clean and polished the dash pots and air filters , Started to make a dash board as this one was missing , photo's tell the story. |
Reply: 99 - 167 |
Goff_Allen |
Posted on: February 3rd, 2018, 20:39:24 Attachment: 12604.jpg - 169.34 KB (1140 views) |
carbs |
Reply: 100 - 167 |
Goff_Allen |
Posted on: February 3rd, 2018, 20:39:52 Attachment: 127.jpg - 172.62 KB (1169 views) |
carbs |
Reply: 101 - 167 |
Goff_Allen |
Posted on: February 3rd, 2018, 20:40:33 Attachment: 128.jpg - 184.65 KB (1141 views) |
dash missing |
Reply: 102 - 167 |
Goff_Allen |
Posted on: February 3rd, 2018, 20:41:25 Attachment: 129.jpg - 190.07 KB (1135 views) |
made a dash but still needs finishing |
Reply: 103 - 167 |
Posted on: February 5th, 2018, 09:08:27 |
Looking good Goff, not too bad a price for the carbs either. |
Reply: 104 - 167 |
