  Mini Marcos Forum  >  General Boards  >  Mini Marcos  >  Marcos 8042 Build
0 Members Browsing (36 Guests)
Pages: « 1, 2, 3, 4, 5, 6 : All Reply Recommend Print
  Author    Marcos 8042 Build  (currently 4,707 views)
Mike_Smith
Posted on: August 23rd, 2022, 16:00:39
Fabricated a simple hold-down for the spare tire.
Mike in Victoria BC - building 8042
Private Message Reply: 75 - 89
Mike_Smith
Posted on: August 23rd, 2022, 16:01:20
A wheel nut keeps everything in place now.
Private Message Reply: 76 - 89
Mike_Smith
Posted on: August 23rd, 2022, 16:02:07
Front carpet and seats now installed for the last time!
Private Message Reply: 77 - 89
Mike_Smith
Posted on: August 23rd, 2022, 16:03:09
Rear carpet sections laid in place. Looks more like a finished car now!
Private Message Reply: 78 - 89
Mike_Smith
Posted on: August 23rd, 2022, 16:04:35
Hood latches fitted and adjusted to hold hood from vibrating.
Private Message Reply: 79 - 89
Mike_Smith
Posted on: August 23rd, 2022, 16:05:26
Side mirrors mounted on the doors. also window lit handle..small bocks of plexiglass bonded to top of window.
Last modified August 23rd, 2022, 16:06:16 by Mike_Smith
Private Message Reply: 80 - 89
Mike_Smith
Posted on: August 23rd, 2022, 16:07:07
Door panels installed.
Private Message Reply: 81 - 89
Mike_Smith
Posted on: August 23rd, 2022, 16:07:55
a much more inviting interior now that its all together
Private Message Reply: 82 - 89
Mike_Smith
Posted on: August 23rd, 2022, 16:10:56
The car has been started and run up the street. There was a bit of lag with the Weber, so a local carb tu9ng guy has dropped by to sort out some fine tuning on the car. It runs much better now and pulls fairly well for an 1100.
Private Message Reply: 83 - 89
Mike_Smith
Posted on: August 23rd, 2022, 16:13:38 Quote Report to Moderator
A few small details to sort out, but finally the car is running, driving and pretty much finished. I have mounted new tires and set up the alignment using the string method. I goes in for a professional alignment in the next few days. For now I am putting a few km on it each day breaking in the engine and looking for any other issues. So far it seems good and is fun to drive!
Is there a way to post a first drive video?
Private Message Reply: 84 - 89
Mike_Smith
Posted on: August 23rd, 2022, 16:17:18
Finished car
Private Message Reply: 85 - 89
Posted on: August 23rd, 2022, 18:27:06 Quote Report to Moderator
Fantastic job, looks really good and you've done a whole lot in not much time.
Private Message Reply: 86 - 89
Mike_Smith
Posted on: August 23rd, 2022, 20:42:23
Quoted from mike brown, posted August 23rd, 2022, 18:27:06 at here
Thanks for the kind words Mike.  I did have the advantage of having the engine already rebuilt and ready to go. But as others may know, it's not a "quick and easy build" as was advertised in the brochures..
I appreciated the help I had getting questions answered on the forum.
This is how it all began!
Private Message Reply: 87 - 89
Posted on: October 1st, 2022, 15:27:05 Quote Report to Moderator
'Rear carpet sections laid in place. Looks more like a finished car now!'
Mike, the car looks great.
A question - in the above photograph, how did you do the rear wheel arch covers.  These look a damn sight neater than what I've achieved for my car!
Last modified October 1st, 2022, 15:28:25 by Graham Bichard
Private Message Reply: 88 - 89
Mike_Smith
Posted on: October 1st, 2022, 23:58:49 Quote Report to Moderator
Quoted from Graham Bichard, posted October 1st, 2022, 15:27:05 at here
I used some automotive upholstery spray contact cement. I sprayed and stuck down the top of the wheel arches  first fitting it as tight as possible. Then I did the lower part and sides.  I sliced slits in the edges along the floor  where it made sense to allow me to have a tight fit on the sides and wrap along on the floor. . I think it looks better in the pictures as it's by no means perfect. I also had to fit and tuck around the seat belt bar, which is why I did the top first. Hope this helps.
Private Message Reply: 89 - 89
Powered by e-blah Platinum 7 Final © 2001-2004   -   October 6th, 2022, 06:22:30
Files opened: 95 | Files closed: 95
