  Mini Marcos Forum  >  General Boards  >  Mini Marcos  >  Marcos 8042 Build
0 Members Browsing (35 Guests)
Pages: « 1, 2, 3, 4, 5 : All Reply Recommend Print
  Author    Marcos 8042 Build  (currently 3,076 views)
Mike_Smith
Posted on: June 15th, 2022, 02:50:46
New radiator fitted and ready to drop the body over..
Mike in Victoria BC - building 8042
Private Message Reply: 60 - 72
Mike_Smith
Posted on: June 15th, 2022, 02:51:38
Down she goes....
Private Message Reply: 61 - 72
Mike_Smith
Posted on: June 15th, 2022, 02:53:41
And shes in.. now to finish up with the rest of the bolts, add the shifter rods, exhaust manifolds, carb distributor and hook up all the engine wiring..   custom gas tank out being Tig welded up so have to get that back before I can think about firing it up.
Private Message Reply: 62 - 72
Posted on: June 17th, 2022, 17:32:40 Quote Report to Moderator
Great progress. It's going to be a sweet car once done.
Private Message Reply: 63 - 72
Mike_Smith
Posted on: June 26th, 2022, 02:39:06 Quote Report to Moderator
Quoted from mike brown, posted June 17th, 2022, 17:32:40 at here
Thanks for the kind comments!
Private Message Reply: 64 - 72
Mike_Smith
Posted on: June 26th, 2022, 02:51:09
Picked up the custom fuel tank I was having welded up today.. will allow a lot more distance between fill ups.  Now to fit it to the car and align the filler tubes.
Private Message Reply: 65 - 72
Mike_Smith
Posted on: June 26th, 2022, 02:57:54
With the engine and front sub frame in place I was also able to cut out the hole for the shift lever and the mounting bracket holes. Now installed on the car.
Private Message Reply: 66 - 72
Mike_Smith
Posted on: June 28th, 2022, 04:29:01
Fuel tank mounted in the car..
Private Message Reply: 67 - 72
Mike_Smith
Posted on: June 28th, 2022, 04:30:01
Filler tube with gas rated hose and stainless T clamps
Private Message Reply: 68 - 72
Mike_Smith
Posted on: June 28th, 2022, 04:30:38
Locking gas cap to finish it all up.
Private Message Reply: 69 - 72
Mike_Smith
Posted on: June 28th, 2022, 04:31:44
Seat belts fitted to car.. will have to come out to fit the carpets.. but I now lknow they will work.
Private Message Reply: 70 - 72
Mike_Smith
Posted on: June 28th, 2022, 04:32:12
Rear belt bar.
Private Message Reply: 71 - 72
Mike_Smith
Posted on: June 28th, 2022, 04:33:49
Engine pretty much plumbed and cables sorted. Just needs heater hoses and the last bit of wiring for the starter solenoid and ignition system.
Private Message Reply: 72 - 72
Powered by e-blah Platinum 7 Final © 2001-2004   -   August 12th, 2022, 12:11:14
Files opened: 103 | Files closed: 103
