0 Members Browsing (41 Guests)
Pages: « ... 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40 : All Reply Recommend Print
  Author    Right - join Part A to Part B etc, etc, etc  (currently 5,440 views)
Posted on: July 9th, 2022, 09:46:52 Quote Report to Moderator
Craig, All,
Looking at the circuit diagram I think I can 'extract' the info for only a second fan.  But am I correct in thinking when comparing your diagram with what I've done, the relay pin 85 and 86 polarity is swapped around?
That is - where I have a +ve feed, you've got a earth?
Hope that makes sense.
Cheers.
Private Message Reply: 585 - 591
Posted on: July 9th, 2022, 10:31:23 Quote Report to Moderator
Proposed relay:
https://www.autoelectricsupplies.co.uk/product/169
With holder:
https://www.autoelectricsupplies.co.uk/product/179/category/37
Using a simple in-line fuse/holder and a single pole, single throw on/off switch - something like this:
https://uk.rs-online.com/web/p.....BwE&gclsrc=aw.ds
(Not sure if this switch is IVA compliant but chosen as an example)
Am I heading on the right path with these items?
Private Message Reply: 586 - 591
Posted on: July 11th, 2022, 09:19:53 Quote Report to Moderator
Quoted from Graham Bichard, posted July 9th, 2022, 09:46:52 at here
Craig, All,
Cheers.
Ordinarily the way that you wire pins 85 & 86 would make no difference to its operation (though 85 is commonly referenced as "coil ground").  However, the relay that you have chosen has an internal diode across pins 85 & 86, and therefore would have to be wired as per my diagram with 85 going to earth.  Alternatively you could go for a relay without a diode:  CBS part number 140201 and wire it as per your diagram.
All that you are doing with 85 & 86 is energising a coil, and it makes no difference which way the current flows with a non diode fitted unit.
Other items all look fine.
Private Message Reply: 587 - 591
Posted on: July 16th, 2022, 14:04:46 Quote Report to Moderator
Thanks Craig.  I didn't realise I'd selected a relay with a diode - no need for that I think.  So I'll look to keep it simple (of course) and get the bits ordered.
Cheers.
Private Message Reply: 588 - 591
Posted on: July 23rd, 2022, 14:47:01 Quote Report to Moderator
Received through the post this week:
Relay & holder, plenty of black & red 17.5Amp cable (I did think about trying to match the MPi loom wire colours, but I'll be marking these cables up with a tag so this was an easier option), plenty of spare connectors.
I purchased the maxi fuse size inline fuse holder as it was only a few quid - I haven't as yet been able to locate a regular size blade fuse inline holder rated at 15A as yet, but will keep looking (until such time as I do the wiring) as it will be more convenient only carrying one size (not rating) of spare fuse.
I bought the switch from RS (along with some cable covering to try and make it look like a 'proper job')- I think it'll be okay (for IVA), the edge profile being similar to the other rectangular rocker switches, but I might hide it away under the dash for the test and mount it correctly on the dash afterwards.
Re-reading Mr Dickens book, he mentions he prefers not to wire the fan through the ignition (albeit he controls the fan with a temperature switch).  I'm tempted - in the name of simplicity in my case, to revisit whether I wire the fan directly i.e. leave out the ignition switch.
Also received the mounting feet for the second fan, which I'd forgotten to order with the fan!
Private Message Reply: 589 - 591
Posted on: July 23rd, 2022, 15:41:18 Quote Report to Moderator
Okay - so after a bit of reassurance here please.
This is a photo of my starter motor area, in particular the red +ve connection.  (Not the clearest of photo's I'm afraid)
Am I correct in thinking it is from here that I take the power to connect to the Relay (connection '30')?
Thank you.
Private Message Reply: 590 - 591
Posted on: January 11th, 2023, 15:46:45 Quote Report to Moderator
Happy New Year All (if it's not too late to say this!).  Anyway, hopefully here's to progressing in 2023!
I haven't posted on here for a while, and have a bit of a rhetorical question.
I've done a little bit of work on the MM including fitting a second fan, but after Christmas I printed off the paperwork to resubmit for another IVA - I'll not be submitting this for a couple of months, but looking up the previous submission I realise this was done back in 2018!
Now I think I might still have an issue with emissions - running the car up to warm it through, the exhaust pipe tip is still very dirty afterwards suggesting to me that the mixture is still too rich.
Since having the car mapped I've changed the lambda sensor, plugs etc.  Don't know if any of this has changed things.
Now the thought I have is I intend to submit the car as is, expecting one of the items to be picked up to be the emissions.  But doing this will give me a list of items to address.
But looking back over my engine build, one of the things that needs to be considered is my fitting of 1.5 roller rockers along with a cam - the extra lift given does seem to adversely affect the emissions by conventional thinking.
But if the car does fail emissions, do we think it'll be best to revert to standard (around 1.3) rockers before getting the car remapped, and accept a little less power?
I would ask the same question of RS Tuning of course, but thought I'd start the discussion on here, to get peoples thoughts.
Also - can't remember if its possible to change the rockers without the need to change the head gasket (the rocker arm retaining bolts I think, are also head retaining bolts)?
Cheers All.
Private Message Reply: 591 - 591
Powered by e-blah Platinum 7 Final © 2001-2004   -   January 29th, 2023, 20:03:09
Files opened: 95 | Files closed: 95
