  Mini Marcos Forum  >  General Boards  >  Mini Jem  >  Heated Screen Current Draw
0 Members Browsing (32 Guests)
  Author    Heated Screen Current Draw  (currently 593 views)
Ron_Murrell
Posted on: June 11th, 2023, 07:07:02 Quote Report to Moderator
Does anybody know what current the heated screens draw?  Do I need a relay?  I intend to switch it with a standard Mini toggle switch (single pole/single throw).
regards
Ron
Posted on: June 11th, 2023, 21:18:19 Quote Report to Moderator
I don't know what they draw but it will definitely need a relay and I would recommend one that cuts out after 10mins or the voltage drops below about 12v. Otherwise you'll melt the switch or flatten the battery.
Private Message Reply: 1 - 3
Ron_Murrell
Posted on: June 11th, 2023, 22:51:51 Quote Report to Moderator
Thanks Mike that is a great point.  That has got me thinking that I should also incorporate a warning light. The timer relays that I have found, so far, can only switch 10 amps so I really should find out the potential current draw also.
regards
Ron
Private Message Reply: 2 - 3
Posted on: August 14th, 2024, 10:42:06 Quote Report to Moderator
You can get one-shot timer modules on ebay, but I haven't found any data sheets for them. They have relays on the board so the contacts are voltage free. You don't need extra relays.
Last modified August 14th, 2024, 10:44:49 by admin
  Private Message Reply: 3 - 3
Powered by e-blah Platinum 7 Final © 2001-2004   -   July 14th, 2025, 22:39:28
Files opened: 147 | Files closed: 147
