  Mini Marcos Forum  >  General Boards  >  Kingfisher Sprint  >  the first
0 Members Browsing (1 Guests)
  Author    the first   (currently 616 views)
scrog
Posted on: July 7th, 2004, 18:30:23
old enough to know better
well here's some pics of my kingfisher
well strive to get on the road this month
scrog
Posted on: July 7th, 2004, 18:37:56
got some 8x13 for the rear almost fill out the arches  can get another
1/8" wide with out risking damage (wheel nuts still have 6 turns  they
tell me thats safe)  they have 195/45/13 tyre's so should stick well
and 6x13  for the front but not fitted yet got to split the disc to get the stud's in (80mm)
 what do you all think
Private Message Reply: 1 - 5
scrog
Posted on: July 7th, 2004, 18:41:37
more pics
Private Message Reply: 2 - 5
Posted on: July 8th, 2004, 10:56:17 Quote Report to Moderator
Just a quick question on the body work, I see that your car suffers from the pink haze, is there any way to get rid of this, my marcos is also a sufferer, I cut the haze back with T-cut but found it very hard to get an even finish/luster, there was alwas some area of each panel that looked "out" . Then the haze started to return within a couple of months.
Neil
Private Message Reply: 3 - 5
Posted on: July 8th, 2004, 14:21:38 Quote Report to Moderator
I think a respray is the only real answer. Some gelcoat colours and especially the 'red' used on Mk. IV Mini Marcoses tends to fade and go streaky after a few years in the sun. It's not just surface oxidisation. I've seen similar fading on a blue D&H Midas.
Richard
  Private Message Reply: 4 - 5
scrog
Posted on: July 8th, 2004, 16:07:15 Quote Report to Moderator
cant afored a respray at the mo    so will try fine wet & dry first
then cutting compound  then t cut   will let you know how it goes
Private Message Reply: 5 - 5
New Thread Mini Marcos Forum  >  Kingfisher Sprint  [ previous | next ] Switch to:
Powered by e-blah Platinum 7 Final © 2001-2004   -   September 21st, 2020, 01:52:40
Files opened: 98 | Files closed: 98
